Applying colors
The Color Palette set provides colors for selection and specifies which colors are available in a Vectorworks file. In a new file, the active document color palette contains only the colors black, white, and gray. As colors are added to the file from other color palettes as well as resources, the active document color palette displays all the colors used in the file. Additional color palettes can be added as needed; colors are organized in standard and/or custom color palettes.
The Color Palette set opens when the Fill color or Pen color box is clicked from the Attributes palette. A similar interface is available from other areas in the application where colors are specified, although the Color By Class option is only available when accessed from the Attributes palette.
To display and manage the colors available for the file:
From the Attributes palette, click one of the color boxes for Fill color (either a Solid or Pattern fill style must be selected) or Pen color (any pen style can be selected).
The Color Palette set opens, displaying the colors in the active color palette.
Parameter
Description
Color by Class
When using the Color Palette set to specify an object’s color, causes the object to take on the color attribute set by the object’s class; see Setting class attributes
Standard Color Picker
Opens the operating system’s color picker for selecting individual colors; see Selecting standard operating system colors
Pick Color
Opens the Pick Color dialog box, for selecting a color from available color palettes; see Selecting a color from a color palette
Color Palette Manager
Opens the Color Palette Manager dialog box, for managing available color palettes and activating additional palettes; see Managing color palettes
Named color display area
Displays any color name information associated with the selected color.
This area also serves to find a named color in the active color palette. To easily find a named color, begin typing; the letters display in the named color display area and the closest color match is selected. Press the Tab key to cycle through the closest matches; pause for several seconds to start the search over.
Search Bar
(Mac only)
To find a named color on the Mac, type in the search bar under the named color display area. Search options are available from the Search bar menu.
Ignore Case: Search will not be case sensitive.
Wrap Around: Search will search entire palette selection rather than starting from the currently selected color.
Contains: Search will search a color’s entire name for the entered text.
Starts With: Search will only show colors that begin with the entered text.
Full Word: Search will ignore partially matched words.
After typing the name of the desired color, click the left and right arrows to cycle through the list of matching colors. Click Done to close the search bar, press Command-F to open the search bar again.
Colors in active palette
Displays the selected active palette’s available colors in either Grid or List view; these colors are available for use in the file
Active palettes
Lists palettes which have been made active for the file with the Color Palette Manager; click a palette name to display its colors for use
Utility Menu
Opens a utility menu to control the color palette sorting and display
Either select a color from one of the file’s color palettes, or click off of the Color Palette set (in the drawing window, for example) to close the color window and set the file’s available colors.
Color palette Utility menu
The options selected from the color palette Utility Menu button at the bottom of the main Color Palette set indicate the color sorting and display.
From the Color Palette set, click the Utility Menu button to open the Utility menu.
Menu/command
Action
View Color Palette as
Select to view the colors in the Color Palette set as a grid of colored squares, or a list of colors and associated names. (In either view, color names are always shown in the display area above the colors as the cursor moves over the colors.)
Sort Color Palette by
Specify the sorting method for the active color palette; select Color to sort by hue (HSV values), Manual to sort according to the order set in the Color Palette Manager, or Alphabetical to sort in ascending or descending order by color name
Place Color Palettes at
Select whether to display active color palettes at the top or bottom of the Color Palette set
Shrink Grid to Fit
In Grid view, color lists of less than 16 rows can be displayed with a Color Palette set option that shrinks to fit the available colors
Select a utility command to change the color palette display or sorting option.
Creating or editing custom color palettes
Creating a color chart
The Attributes palette
Transferring attributes
